Still working the bugs out after the head gasket change.
I got the car back together, found a few more coolant leaks, fixed them. The thing starts and runs perfectly. But will not idle after initial start. Good power, no white smoke, no codes. Then it will start rough idle and die, triggering a P0300- multiple misfire. Is it possible that the two cylinders that had coolant in them damaged the spark plugs? I was thinking maybe the plugs contacting coolant would repeatedly quench them and cause failure.
But it runs so smoothly that it seems unlikely. Also...the off-idle spark advance is 32 degrees. This seems high to me. Is it too high and does this have anything to do with the misfires? Does this mean I have the VVT wrong?
2007 S40 Throwing P0300 code after head gasket change
Craigd2599
- Year and Model: 2007 S40.
- Has thanked: 3 times
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
- 1066 Views
Last post by Craigd2599
- 16 Replies
- 12042 Views
Last post by Austingrayy
- 1173 Views
Last post by mf70
- 1385 Views
Last post by kmaninaustin
- 18 Replies
- 5857 Views
