So I bought the car, got a great deal and just getting all set for winter.
Tasks done so far, Need suggestions of anything else they would suggest
2004 c70 82k miles
1. Timing belt tensioner, and idler
2. FLushed coolant, the swapped over to Evan's waterless
3. New front struts
4. 5 speed auto Valve body, cured the bad downshift issues that full flush did not resolve, shifts 100% now
5. Flushed PS fluid with new, was a little noisy, unsure if wrong fluid was used before me
Car seems all good, was also looking to maybe scotch gaurd or waterproof top somehow
2004 c70 New to me car, had previously sat a lot
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Magnifine filter on transmission line. Can't hurt.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
If unsure about prior maintenance, I would change the brake fluid as well. And of course timing belt. And check age of tires, beyond ten years replace regardless of wear.
- regent
- Has thanked: 2 times
- Been thanked: 12 times
At 82Kmi, I would check the condition of the PCV system and service it if records are unavailable.
Fuel filter and a set of spark plugs are on the list as well. If/when you are doing the PCV or the T-Belt, you may want to replace the thermostat (while you are at it), and give all motor mounts (including the lower torque mount at the transmission) a good visual.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 203 Replies
- 10362 Views
Last post by volvolugnut
- 308 Replies
- 125340 Views
- 2690 Views
Last post by dono
- 232 Views
Last post by DaveDJ3
- 594 Views
