Ok, I've kinda made a mess out of my car. I just recently reworked the head gasket and rebuilt a 15g turbo. While I was in there I decided to install the white injectors, a TCU and a CBV from IPD. I used the blue spring in the CBV. All new vacuum lines, radiator etc. My plan was to use a 4.4 ECU out of the 1998 T5 car.
The ECU problem, Come to fine'd out my 97 GLT already had a 4.4 in it BUT the a/c controller is a 4.3 so this ECU works like it should except I'm dumping all my boost out of the waste gate. The ECU I got from the T5 has the power that I want, its a 4.4 and the a/c is a 4.4. So, when I run the T5 ECU the a/c will not work.
So I'm stuck in the middle between A/C and no power or power and no A/C. What I need is:
A. take the T5 ECU and flash the 4.3 a/c controller on it
B. Take the GLT ECU and flash the T5 tune on it.
I would really like to flash the A/C onto the T5 ECU but I haven't a clue and the reading I've done isn't helping.
97 GLT/T5 ECU FLASH no a/c
1ezliving4ume
- Year and Model: 850 glt turbo 1997
- Has thanked: 311 times
- Been thanked: 817 times
I'm partly to blame for this mess ... did you get the A/C sorted out yet? I know the online instructions have a steep learning curve plus you need the right hardware, it is a hassle to get going. I can flash on the A/C for you no charge, would split shipping with you, let me know. PM me here unless you still have my email from before.
- 757 Views
- 11 Replies
- 3100 Views
Last post by tryingbe
- 4362 Views
Last post by Clemens
- 2406 Views
Last post by shaker_chi
- 1575 Views
Last post by wyoben
