1998 S70 replaced pcv oil trap and is worse than before
jack thompson
- Year and Model: S70 1998
so i replaced the oil trap and all the vacuum lines that were rotten and when i started the car it blew the dipstick out could i have the lines switched
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Short answer: Yes.
Follow-up question; did you only replace the oil trap, and not the lines? Did you clean out the PTC? Did you check to see if the ports to the block were clear?
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- misha
- Has thanked: 155 times
- Been thanked: 432 times
What ptc?
Where did you read that it's a turbo?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
you need to check the ports on the engine blocks are clear?
use a zip tie... or a screw to pull the blockage out... try not to push it in....
i would do oil change right after...
yeah check all hoses... including the PTC... which is probably gummed up....
you could vent to air the PTC hose and cap the PTC... and see if that helps....
Sommerfeldt
Ouch... you're right. I assumed.misha wrote:What ptc?
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
We don't know whether OP's car is NA or turbo.sk55 wrote: yeah check all hoses... including the PTC... which is probably gummed up....
Sommerfeldt
OK... Misha already pointed that out, so I think that's enough of that. The point is that OP needs to;polskamafia mjl wrote:We don't know whether OP's car is NA or turbo.
1) See that all hoses are connected properly
2) Check that the PTC (if the car's a turbo) is clear
3) Make sure that all the ports are clean
Those are the main points, no matter what the car.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
Instead of speculating on whether it's a turbo or not, why not just tell him to check that the vacuum source to the pcv system is clear?
That's basically what the PTC does, right?
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
Sommerfeldt
No... It's there to deal with the moist air coming from the engine right after start... It's the Positive Temperature Coefficient heater nipple...alschnertz wrote:Instead of speculating on whether it's a turbo or not, why not just tell him to check that the vacuum source to the pcv system is clear?
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 27 Replies
- 4116 Views
Last post by bmdubya1198
- 1446 Views
- 3616 Views
Last post by pgill
- 3561 Views
Last post by URDRWHO
- 3782 Views
Last post by leavealetter
