2007 XC90 3.2L AWD - power steering coupler
Recently had the serpentine belt, idler pulley & bearing failed. Symptom was high water temp. Routing the new belt is a task. The p.s. unit is loose & has belt routed around pulley. The p.s. pulley has a coupling that drives the water pump. It appears that the water pump coupling is driven by the spring. The coupling looks football or diamond shaped. How does spring affix to water pump coupling? Any info regarding this job is appreciated. Thanks.
- 3334 Views
Last post by cuhfs
- 494 Views
Last post by kevins s70
- 687 Views
Last post by shiloh51933
- 1370 Views
Last post by cmbfoto
- 19 Replies
- 2718 Views
Last post by deano1
