1998 xc-70 mystery part to me
Clockboy
Year and Model: 05 xc70, v70 2.5t 06
Has thanked: 2 times
Post by Clockboy »
I was chasing down a leak that seems to be coming from the engine side of the turbo return line. Yay me.
There is a seemingly aluminum box that sits directly behind the oil drain plug. It has a down turned front edge and a bunch of screws holding a bottom plate on it. What is it. I can take an image if needed.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
I don't have experience on the AWD cars, but the Chilton manual shows a good picture of it on the suspension picture of the underside of a '98 V/R.
AWD guys, what is it?
Current Volvos:
regent
Year and Model: 2015 XC60 T5
Been thanked: 12 times
Post by regent »
Clockboy wrote:... aluminum box that sits directly behind the oil drain plug...
Sounds like the oil cooler http://volvopartslisle.com/assembly/714 ... ing-System
... but not sure if you have one; could you post a picture - we'll figure it out :)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
FLXC90
Post by FLXC90 »
In Chilton picture, box sits just above bottom-of-pan level, and is oriented horizontally vs. oil cooler vertical placement. P/N label (was) on rear face of unit, almost looks like an Electrical control box of some sort.
'98 FWD turbo cars had oil cooler in radiator, and lines come off lower block, above this box. Dunno about AWD, can you reach in the space above and feel if there are lines attached to the top of the box?
Current Volvos:
Clockboy
Post by Clockboy »
Yes, it is horizontally mounted unlike the oil cooler. The oil cooler lines run to the opposite side of the engine at the lower corner - right where the flap is under the passenger tire. Electrical makes sense - as I remember it had regular screws holding the cover on. It could be some sort of 'junction box'. Never even thought of that, but it seems to make sense. Stole an image from the web. Different year, but same box.
bskeels
Year and Model: 1997 Volvo 960
Been thanked: 3 times
Post by bskeels »
I am not sure what they call it, or what it is actually for, I removed mine to do seals in the bevel gear, I am guessing it is for vibrations or something like that, it is quite heavy.
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
FLXC90
Post by FLXC90 »
okay makes sense, a counterweight for the torque through the bevel gear.
Current Volvos:
Clockboy
Post by Clockboy »
What is inside of it?
bskeels
Post by bskeels »
I haven't taken it apart, I only removed from the bevel gear where it attaches with 3 bolts.
The Fleet
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
Clockboy
Post by Clockboy »
Next time I'm under there I'm tempted to take off that cover, but with my luck a million small ball bearings will cascade out and get lost in the gravel driveway.
