2002 S60 2.4t. tranny stops slipping with t stat removed
Spinningcain
- Year and Model: 2002 S60 2.4t
Hi I have a 02 S60 2.4t with 130,000 miles on it. It has the shift flares pretty bad. I decided to change out the t stat and found out I apparently need to buy the entire housing. Anyway in the mean time I left it out. I know it will throw a code for this eventually. The strange thing is my transmission issues are completely gone. I drove it alot and it seens to be normal now. I'm just trying to wrap my head around this I can only think that it is cooling the tranny more then it did before. Any thoughts?
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Yes, ATF runs more cool now. It will have limited effect, the flare will eventually return. I know this, because V70's bad shifts issue was first gone after external oil cooler was fitted, but in a few months it returned back. Fixed by a reman. valve body.
Spinningcain
Ahh makes sense. I just need to bite the bullet on the valve body. Thanks for the reply
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Just thinking, maybe replacing the fluid meanwhile will help a bit. Old fluid has lost it's properties as transmission fluids degrade with heat. Still keeping no thermostat and a valve body job soon in view.
- 615 Views
Last post by 850TurboTurtle
- 928 Views
Last post by matthew1
- 1937 Views
Last post by sergio
- 1347 Views
- 16 Replies
- 4763 Views
Last post by coded9
