My rear view mirror wants to stay in the same place, which is not where I want it to be. If I adjust it upwards slightly, into the place where I need it to be to see correctly out of the rear window, it immediately slips back to where it started from. Ditto if I adjust it downward slightly. I have to move it way out of alignment, either up or down for it to stay there.
It's almost as if there is some kind of worn notch inside the suspension pillar clamp assembly which it slips back into when it isn't moved far enough.
Anyone had the same experience, or know how to disassemble the rear view mirror assembly so that I can find out why it's doing this please?
2007 S80 Rear View Mirror won't stay in place
- 696 Views
Last post by Dstrau
- 640 Views
Last post by Lucky_Seven
- 1133 Views
Last post by phils94850
- 1015 Views
Last post by jimmy57
- 823 Views
