2003 s60 alarm relay
dkelly0802
- Year and Model: s60 2003
hi im new here was wondering if anyone can help me out. Im looking for the 210 211 relay for the alarm and dont know how to identify it. I know its under the dash but not sure which one it is. Any help would be greatly appreciated. thanks
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Welcome aboard!
Not sure what 210 211 is but here are all the relays, see if attached can help you identify the one you need
S60 S80 2003 Relays.pdf- (124.13 KiB) Downloaded 1960 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
dkelly0802
Thank you
dkelly0802
Hi the reason i was trying to locate this relay is i read somewhere that you can override the factory alarm. Now Im being told that you cant disable the alarm and that anything i do to try to fix the car will need a software update to sinc the new part to the car. Is this true? My problem is sometimes when i drive the car a short distance and try to start it after running an errand the immobilizer kicks in and kills the ignition. After a few hours or so the car usually starts. There is a message that shows up that says alarm maintenance required. Any ideas? thanks
- regent
If you are getting nuisance alarm trigger events with relevant DIM messages, take a look at this thread, it will probably help you solve your problem:
https://www.matthewsvolvosite.com/forums ... 11&t=17479
To identify a bad alarm module, it is best to read the car for codes.
However, it is the battery inside the alarm module that usually gives up the ghost after this many years in service, which makes the alarm module the primary suspect.
2015 BMW 335i
2015 BMW 335i
I just replaced the alarm siren on my 2004 S60. I used my small channel lock pliers on the security bold and it came out with no issues (no need to cut a slot in it with a dremel power tool). I put it back and the same way. I ordered the pop rivets on amazon and the best price I found on a new siren was at niellovolvoparts dot com. I split the old one open and the red wire was disintegrated all the way to the connector and the battery looks like it fried two capacitors. That is more work than I would have wanted to take on, so I am glad I purchased a new siren. The dealership wanted $80 more for the siren, who knows how much they would have charged to put it in!
- 3954 Views
Last post by ZootAllures
- 1888 Views
Last post by jonesg
- 2192 Views
Last post by Sailsman
- 4087 Views
Last post by Lowmiles
- 2228 Views
Last post by mecheng
