Hi,
I just wanted to get some feedback in terms of the expected life of the engine/transmission on this car before any overhaul is necessary. The car has been properly maintained and currently has just under 200K miles. I appreciate it.
1996 850R Engine/Transmission Life
- Has thanked: 312 times
- Been thanked: 818 times
You can expect 300k or more from the transmission, since you say car has been properly maintained (i.e. assuming the transmission has not been beat on). There have been failures before that but they are very uncommon to rare.
Hopefully there have been some transmission fluid changes along the way but if not, then 200k is a fine time to start with a vehicle that was properly maintained so far. Drain 3.5 quarts using the plug, refill exactly the same amount, repeat in 500 miles until you have done it 3 times. Now you can wait 30k at which point do a full 14 qt exchange.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
If it is properly maintained,it will run another 200k without problems.
200k is nothing for these cars.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
twice as long as the distance from the middle to the parts store?
my beater 98 N/A has 230 right now, and the motor and trans are great. I could see an easy 300 out of them. Robert had 400+ on a Volvo of his, there are several posters here that are 300+. you've been here long enough to know the basics, oil changes, timing belts, PCV, trans fluid changes.
Current Volvos:
- 2418 Views
Last post by RickHaleParker
- 1470 Views
Last post by Acknar
- 1853 Views
Last post by nickm
- 19 Replies
- 5553 Views
Last post by beigg
- 3065 Views
Last post by JLGParis
