I need your help!!!
Have a Volvo s40 2001 1,9t 140k and having issues.
Had it for almost 2 years.
Starting to get issues after 4 month trouble starting after driving and trying to restart after standing for 10-60+ minutes. It starts when cold..then driving for 30-90 min. Stops and then trying to start it after a break. Can't get it to turn over. Battery good..tried starting gas in the air intake. Changed fuel pressure reg...worked! 3 month later same thing started all over again. First week it starts with me pushing down the gas. Mechanic changed vacuum pump..starts again. 3-4 month later...same thing. Changed chrankshaft sensor after a mechanic said that was wrong...worked for 2 days. Drove for 1,5h,..stops and try to restart after 20 min. Doesn't start. Spray start gas..gets it barely start after working gas pedal for 10 sec. New mechanic...says spark plugs are all fouled out..change it. Pressure test all..says engine is good. Drives home 1,5 h...goes out to test start after 1 h...same problem. I'm so frustrated and desperate!! I need help!
Used 91 octane...gramma driven by me.
Coil pack was not issue according to last mechanic.
So basically starts cold...after dr one for a while and then standing for 10 min plus...no start. Starter works..brand new spark plugs.
Sea level and 6k ft Colorado.
Help me
2001 S40 starting problem
- 964 Views
Last post by S40VolVo01NC
- 1135 Views
Last post by xlewis0
- 1254 Views
Last post by james02s40
- 1093 Views
Last post by difflock54
- 1250 Views
Last post by RickHaleParker
