Searched Forum, lots on SPARK plugs, but nothing (I could find) on CVVT plugs.
After replacing exhaust CVVT, I noticed the gear/hub was turning very rough, throughout its small range of rotation ... an awful, metal-to-metal type of feel. Didn't seem right at all.
Knew I hadn't overtorqued the camshaft screw (88 ft-lb), but figured I'd better remove the hub. Took out the plug, and, lo-and-behold, the binding was gone. Put the plug back in, and ... binding again! The plug is actually bottoming out on the screw head. This can't be by design. Does this binding go away when the cavity is pressurized? Was there a spacer that fell out when I removed the old hub? It's the same part number I took out, Volvo OEM 9497786: IPD and eEuro say it fits, FCP says it does not.
Anyone else experienced this?
2007 S60T5 CVVT Plug bottoms out on Camshaft screw
- 1145 Views
Last post by vtl
- 867 Views
Last post by phils94850
- 1212 Views
Last post by fields 100
- 270 Views
Last post by foggydogg
- 538 Views
Last post by azureblue
