Lower Engine Torque Rod Discontinued, Recommendations?
BigRed
Year and Model: V70R 1998
Post by BigRed »
I need to replace the lower engine torque rod on my '98 V70R. It's the mount from sub-frame, to transmission. Looking around it is part number 9470836 which is discontinued. FCP has an aftermarket unit from Rein, but I haven't read anything good about them. I did find a Corteco one on PartsGeek, and a Hutchinson on eEuroparts. There is conflicting information as to fitment on FWD vs AWD vehicles.
Can anyone confirm fitment and make a recommendation to manufacturer?
Thank you.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
PN 9470836 fits both FWD and AWD V70.
http://www.volvopartswarehouse.com/p/Vo ... 70836.html
I am not a fan of Pro Part Sweden (Chinese stuff anyway), however, if you go to ebay and search, you will see PPS torque rod mount for $33 and it is all polyurethane. So, it seems like a good part.
Otherwise, search for Hutchinson brand.
Big Will
Year and Model: 1998 V70 AWD
Post by Big Will »
Have they changed the mount recently? The back of the mount (the bracket with the smaller bushing) has a slightly different orientation of the bolt holes on the AWD version. You can machine it a bit to make the FWD version fit though or use the bracket from your old AWD mount and install a new poly bushing.
98 V70 AWD - M58 Gearbox - Beüst custome tune, 20T turbo w/angled exhaust housing, Green injectors, Öhlins Roadholding Suspension, B MAC Built Engine
BigRed
Post by BigRed »
Big Will wrote:...use the bracket from your old AWD mount and install a new poly bushing.
Do you know where I could purchase a poly bushing that would fit in the smaller section? IPd has one for the larger section, though it doesn't show as compatible with the AWD vehicles. Though I doubt the actual bushings are a different size.
BigRed
Post by BigRed »
Big Will
Post by Big Will »
Sorry, just seeing this now. Glad you found it.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
It's easy enough to replace that it might be worth trying the cheapie.
