I bought my Volvo few months ago and my power door locks work as they should but recently blinkers stopped flashing to confirm that the doors are locked. Is it possible that somehow I disabled this feature?
Blinkers were only flashing when I was locking the car (one steady, long flash) but never flashed when I opened it.
Also, there was never any beep to confirm locking and unlocking. Was it ever a feature on this car?
Is there a way to turn the blinkers back on to signal locking?
2008 S60 Power locks work fine but blinkers do not flash.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Maybe the siren module is giving up. This takes care of the sound and has a small battery inside known to start leaking after more than 5 years.
Normally the blinkers should still flash when locking the doors, there might be something like a hood switch that doesn't close properly.
- regent
- Has thanked: 2 times
- Been thanked: 12 times
The hood closed switch is usually 'cured' if you drop the hood from at least 12" to close with a bang (ugly but works). Any other "open" input will trigger a DIM message and the "amber idiot triangle" (trunk lid for example)
I think the 'beep' responses (upon armed/disarmed confirm) and the two-stage unlocking are all optional (e.g. programmable ON/OFF activations with VIDA)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
Slamming the hood fixed the blinkers. Thanks.
Now, to activate beep, can I do it by myself or do I have to see Volvo tech? I can't find anything about power door lock beep in the manual. Maybe it's not a feature on this model?
JRL
- Year and Model: Several
- Been thanked: 16 times
I don't think it can be made to beep
- regent
(Not that I find the beep so essential)
I may have to play with my VIDA some more to see if I can find a workaround to make it cooperate
2015 BMW 335i
2015 BMW 335i
- 2019 Views
Last post by firstv70volvo
- 5730 Views
Last post by Riley8282
- 1395 Views
Last post by SuperHerman
- 1081 Views
Last post by MadeInJapan
- 1046 Views
