Good evening to all.
I have a Volvo V50, 1.6d, 2006, engine D4164T, Europe.
At last VIDA diagnostic appear the following errors:
1- ECM-68BD ECM Intercooler bypass throttle - signal missing
2- ECM-9120 Inlet valve control - signal missing
I checked after VIDA instructions with each plot measuring device and obtained the following values (picture attached).
Two of the plots (# 1 and # 2), the device shows me 0 volts but when I switched voltage wiring #4+#5 and #4+#6 , I obtain value (voltage), so the wires are not interrupted.
Also I had a error on CAN ---
3- CEM-DF11 CAN-H, high speed network Signal missing.
After all the voltage/resistance measurement according to VIDA instruction I obtained the values as in the VIDA.
In the Electronic wiring diagram volvo v50 from Electronic Wiring Diagram (EWD) of Volvo Car Corporation,
a) -- on the ---- EWD 3984202 S40 (04-) 2005 Supplement -- it say that must be 10 relays:
15/31 Engine compartment distribution box
Pos Relay function
R1 2/165 Relay immobilizer
R2 2/17 Relay, horn
R4 2/34 Relay, front fog lights
R5 2/142 Relay, pre-heater, fuel filter
R8 2/159.2 Relay, infotainment, extra
R9 2/182 Relay, headlight washer motor
R10 2/82 Relay, heated rear window
R11 2/22 Relay, climate control system
R13 2/35 Relay, starter motor
R14 2/32 Main relay, engine management system
b)- on the --- 3990202 S40 (04-) 2006 -- it say that must be 8 relays:
Pos Relay function
R1 2/165 Relay, immobilizer
R2 2/17 Relay, horn
The strange think is that in both cases on my car is missing the relay nr 1. An I check several time, there are not electrical wires on the distribution box in the place this relay supose to be.
Have somebody any idee regarding this problem and when I can find the corect Electronic Wiring Diagram for my car ?
Also, it says that the ground connection from the CAN-H are also on the A-pillar, upper, windscreen level, left/right.
I check today and are only the wires from SRS/airbags system.
Do you know is there are groung connection on the A-pillar for the CAN-H ?
Thank you.
2006, V50, 1.6d, Intercooler bypass throttle
- 11 Replies
- 1944 Views
Last post by Clemens
- 2823 Views
Last post by MoVolvos
- 1860 Views
Last post by Sergio001
- 1675 Views
- 3447 Views
Last post by MadeInJapan
