2003 S40 Toyota neutral safety switch
steve090
Year and Model: 2003 S40
Post by steve090 »
Ever since I have had my Volvo, I have had intermittent starting problems. At first I thought it was the immobilizer or other things but I became convinced that it was the neutral safety switch.
So today I pulled mine and to my surprise, I had a Toyota part installed #84540. Well it has been working for over a year and for the most part was a nuisance but never did I have to get towed and lately I am off and going in less than 5 minutes.
After removing the switch, I found out it was riveted so I had to drill it apart and I found some tiny bolts to bolt it back together having to increase the diameter a bit.
I cleaned it although it was not to dirty and applied some dielectric grease and it had six springs and clips so it was a bit of a pain to get back together.
Has anyone heard of a Toyota neutral safety switch on a Volvo, seems odd, even though some parts are interchangeable. At least I know the condition inside so I can continue to use it and should not have any problems.
Interested in other peoples insight, I may pick up an original Volvo part, but someone had to know what they were doing when they put the Toyota one on.
Thanks
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
I doubt Volvo spec'd a Toyota part.
'84 Prelude
'06 MPV
'13 Ford Focus SE
difflock54
Year and Model: V40 Nordic 2002
Has thanked: 7 times
Been thanked: 2 times
Post by difflock54 »
You have auto transmission? AW.
Aisin Warner transmissions are part owned by Toyota and a lot of their technology and expertise has gone into their designs/operations over many years.
Based on that it is probable that some components are compatible?
