98 V70: Removing lower turbo vac hose
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
Having a tough time with this one, especially flat on my back with the car on ramps. This old hose is really stuck on tight and I'm unable to reach the 'pinchers' on the green, metal clamp from underneath. They're up on top!
From above, I can't even see down into this area. Any ideas/suggestions from those who have replaced this hose?
TIA.
M1 10W-30 HM
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
All of those hoses have been PITAS on my car... The hoses are fused to the metal in most cases, so I took a Dremel cutting wheel to them in the end.
Smell was awful, but they came off... :D
- S
[Sold] '97 S70 T5
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
Tenacity and a screwdriver for leverage
'00 S70, '04 S60 and the never ending quest for Stage Zero
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Been there done that, use a very long screwdriver (such as 16" long).
Your life will be much easier.
jcdillin
Year and Model: 06 V70R
Been thanked: 3 times
Post by jcdillin »
I cut the hose off at the nipple and just used some tiny channel locks to twist it off.
sleddriver
I worked on this yesterday, from above this time. The hose was able to resist my pulling without breaking, so I let it be...for now. Tried to pinch the green metal clamp using pliers and a mirror, but just managed to rotate it out of position. Royal PITA.
M1 10W-30 HM
Clockboy
Year and Model: 05 xc70, v70 2.5t 06
Has thanked: 2 times
Post by Clockboy »
I had taken the air intake hose and airbox out while doing something else and decided to change the hoses to the turbo. I used a small set of pliers with an angled end and was able to get it no prob. It was difficult to get the spring clamp undone so just grabbed one side and bent it into submission. Once everything was out of the way from above it was really no big deal. A small pliers was key. Even with the intake bits out it was too tight for the full size pliers I had initially tried to use.
ferocity02
Year and Model: 1998 S70 GLT
Been thanked: 14 times
Post by ferocity02 »
Does that hoes to the 3-way solenoid thing that is attached to the rear of the airbox? If so, mine needs to be replaced too, it's rock solid!
benpineapple
Year and Model: '06 V50 T5, '13 XC90
Has thanked: 5 times
Been thanked: 4 times
Post by benpineapple »
I've used a candle-lighter to heat and weaken the rubber. Only did that on parts where I knew it was a metal fitting, and after I'd cut away as much as possible, to avoid bits falling into the ports. Either way, pain in the ass.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Clockboy wrote:I had taken the air intake hose and airbox out while doing something else and decided to change the hoses to the turbo. I used a small set of pliers with an angled end and was able to get it no prob. ...
This!
Accessing those turbo hoses is only a minor inconvenience one you move the other stuff out of the way. Totally worth it.
