It's time to tweak up my 93 for winter service. This car is a great starter and has been very reliable since I bought it in 2008 (my first Volvo).
For the last 4 years, I've driven it mainly November to May.
I know I need to replace the exhaust manifold "donut" gasket. I've seen a couple advertised on Amazon, Partsgeek, etc., one branded by Walker. The aftermarket ones have tended to not last very long, but the $60.00 plus for the Volvo version does give me pause.
Has anyone found a decent cheap replacement?
93 850 Any decent a.m. exhaust manifold gaskets?
- Year and Model: Many Volvos
- Been thanked: 76 times
Are you sure it is the gasket and not the flex joint itself? I have had a bunch of trouble with the flex joints cracking but for the gasket I just used whatever OBX sent me and it worked fine. I'm sure they don't send OEM.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
I had a flex joint crack on my 96, too, and had to replace the manifold with one of those $140.00 jobs. So far, after one year, it's okay.
But on my 93, before the flex joint, they used a coupling of the hard pipe with the hard manifold flange and a somewhat soft donut gasket between them. All held together with two long bolts backed with very strong springs to hold it tight but allow some play with engine movement.
I think one of the problems with this design is guessing how tight the bolts should be given the quality of the replacement gasket.
I can see the one I installed 4 or 5 years ago is pretty squashed. I'll probably take a chance with the Walker branded one I've seen on line, see how that works.
- 23 Replies
- 3478 Views
- 1570 Views
Last post by beigg
- 872 Views
Last post by stephansvolvo
- 651 Views
- 851 Views
Last post by KevinCro
