1992 240 Wagon Buzz from far left of dash
- hockeyjake1997
- Year and Model: 240 1992
Does anyone know what may be causing a very occasional buzzing noise from the left side of my dashboard? It almost sounds as if its coming from inside the furthest left vent. When it happens it only happens for a second, and sounds like an electronic buzz, or the noise you get when lightly touching an object to a spinning fan.
CaliforniaJohnny240
- Year and Model: 240 1990
I recently purchased a 1993 245 from a guy and during the test drive a similar noise occurred. It happened when the car was traveling over 60 MPH. It was intermittent and sounded kind of like a hornets nest in the dash area. It turned out to be the windshield weather strip was old and was lose enough that it was catching the wind and vibrating. The car is dark green, almost black. So i used some black duct tape above the windshield to temporarily secure the weatherstrip. I will address this problem permanently in the next several months seeing as this vehicle has a lot of deferred maintenance issues. Maybe you could give some more of the circumstances and symptoms of your issue so we can help you figure it out better. Thanks
- hockeyjake1997
I sorted it out actually, thank you. just a loose bit of trim I hadnt noticed was loose.CaliforniaJohnny240 wrote:
- 5322 Views
Last post by oragex
- 1704 Views
Last post by mecheng
- 4933 Views
Last post by br0dy519
- 1342 Views
Last post by mf70
- 996 Views
Last post by kimothyanne
