I have had a search of the topics but can't find the answer to this one.
XC90 T6 2004
Front left drive when steering is on full lock either left or right turn I am getting a constant speed related clicking/knocking sound as I pull away. Once in the dead ahead position the knocking clicking sound goes away. There is no sound if the vehicle is stationary on full lock. I think it might be the CV joint but wondered if anyone else had had the same noise and found the problem and cure. Thanks
2004 XC90 T6 Knocking noise when moving on full lock
tailor
- Year and Model: 2004 XC90 2.5T AWD
- Been thanked: 2 times
Front bushings and a inner tie rod plus ball joints & a motor mount solved my issue.Mine was more of a groan and creak plus i was diving when braking which is also resolved.
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Abe Gottschalk
I had this problem. We replaced the left front axle and the problem went away. These years had problems with the trans leaking into the axle and mixing axle grease into the trans fluid. Have this checked and if there is any bit of doubt have the trans flushed. I wish I did. Our second trans went about 6 mos later.
2009 XC90 V8 AWD - R Design
2000 V70 5spd manual - crossing into the 300,000 mile club
- 1718 Views
Last post by darrylrobert
- 7055 Views
Last post by JAWS3127
- 2420 Views
Last post by Ou2mame
- 1905 Views
Last post by fisker247
- 703 Views
Last post by FireFox31
