My trans has solid shifts, Fluid not burnt.
Symptoms:1-2 shift normal speed. 2-3, hangs in 2nd until I almost completely take my foot off the gas. 3-4 quick. 4-3 downshift with very little throttle.
Throttle cable to trans has been backed off almost as far as it can go.
Ideas?
1990 740 Turbo Auto trans shifting issue
5ft24
- Year and Model: 2005 XC90 V8 AWD
- Has thanked: 20 times
- Been thanked: 12 times
It has been adjusted by the manual's procedure, and even backed off a TON to see if it made any difference... None with the 2-3 shift. and manually pulling the cable there isn't any binding or stickinglummert wrote:Probably related to the kick down cable.
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
While reading about adjusting the kickdown cable (I recently had an issue with shifting on my 1988 760 Turbo Wagon) I noticed mention of first checking the adjustment of the throttle linkage.
1988 Volvo 760 Turbo Wagon
5ft24
Nope. Haven't touched the trans itself. I am planning on doing a fluid/filter change when the weather lets up a little here. Just because I don't know when it was ever done.93Regina wrote:Did you make or install an OD shift plate via removing solenoid?5ft24 wrote:...manually pulling the cable there isn't any binding or sticking
lummert
No need to replace the filter screen. Just remove the drain plug to drain the pan (holds about 4 quarts). Replace with new dexron lll fluid . Do a fluid flush if needed.
5ft24
Is Dexron III still available, or has it been completely replaced with the Synthetic Blend Dexron V or VI?
lummert wrote:No need to replace the filter screen. Just remove the drain plug to drain the pan (holds about 4 quarts). Replace with new dexron lll fluid . Do a fluid flush if needed.
- 966 Views
Last post by Vancethevolvo
- 881 Views
Last post by robin_740
- 287 Views
- 807 Views
Last post by FMradio
- 1026 Views
