1997 850 t5 turbo Anyone removed the catalytic con.? Mine bl
mescalinedreamz
- Year and Model: 850 t5 1997
I just bought the car and noticed a slight smell of exhaust. I looked down the back of the engine and seen the catalytic converter. The cat was blown, that steel braiding was busted and spread out. I live in Michigan and so I don't have to worry about emissions. I plan on putting a pipe in it's place. I was wondering if anyone has done the same and what size pipe do I need and length? Clamp it or weld? The car is turbocharged if that matters. It would be great if someone could give me a list of all parts they used and any tips. Thanks guys!
- Year and Model: Many Volvos
- Been thanked: 76 times
The ECU will post a P0420 code and perhaps some others so the Check Engine Light will always be on. I would clamp it so that it would be easier to actually put a proper converter back in. You can get an aftermarket converter pretty cheap if you send in the blown one as a core, check eBay.
I've never straight piped one so can't tell you the pipe sizes but a tape measure will go a long way. Just measure stuff. You will likely need to trim the pipes to get everything to fit.
I use Ma and Pa muffler shops to repair exhaust systems but they won't touch this one for fear of the fine and possible jail time.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Yes you can put a straight pipe instead cat BUT you MUST disconnect rear o2 sensor connector.Like Lee said...you will have permanently check engine light on.
If you don't disconnect rear o2 sensor from it's connector after removal of a cat,you will have issues.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1212 Views
Last post by Cookeh
- 4895 Views
Last post by MadeInJapan
- 1364 Views
Last post by Anthony303
- 18 Replies
- 3097 Views
- 946 Views
Last post by xHeart
