2002 S40 coolant leak
The A/C button in my 2002 S40 kept flickering on and off and then about 20 mins later I had coolant leaking from the front right side bottom of the car. The dealer said it was caused by the bottom radiator hose was bad and the bleeder screw was leaking. The fix the dealer offered was to change the bottom hose and my radiator with a new radiator - $680.00 Why do I need a new radiator and can't I just replace the bleeder screw. The dealer said the bleeder screw is not available by itself and so I would need to buy a new radiator. Can anyone confirm that this is true or is there a less expensive fix?
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
Not sure why the A/C light was flickering because of a bad radiator hose.
Where is this "bleeder screw"?
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- kranz
- Year and Model: '98 V70 NA stick
- Been thanked: 8 times
I can only relate my experience with a '98 V70. A year or two ago, I had a leaking bleeder screw on the original stock radiator. I was able to get one from one of the forum sponsors. However, just last month I replaced the radiator itself. It had begun to leak with 199K miles on it.
Les is more.
Kranz: Where is the bleeder screw? Is it the same thing as the drain plug? And are you saying I am not able to purchase the bleeder screw alone? I don't know much about these parts but would hate to purchase a whole new radiator if not necessary. Please advice.
Alschnertz: Volvo said because the coolant was leaked the car started to overheat which caused the compressor to kick in and out as needed hence the a/c button flickering on and off. If this is not true please advice.
- alschnertz
Oh, the drain plug, that would make more sense. I've been all over my '01 and don't recall ever seeing a "bleeder screw". But maybe a '02 is different.
Generally a bleeder screw would be at the highest point of the cooling system. Because it is used to "bleed" the air out of the system.
I think it would be unusual for the drain plug itself to fail. However, the bung (female part of the connection) that the drain plug (male part of the connection) screws into is part of the radiator. So if the bung / radiator connection has failed, it is likely that you would need a new radiator.
That's my guess so far.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- kranz
OK, I meant the drain plug or threaded fitting on the bottom of the radiator used to drain the radiator core. Didn't mean to add confusion. Mine was made of plastic and began to leak. A new one solved the problem.
I did a quick check for your model and there is a Genuine Volvo 30644376 drain cock available for a nominal sum from a couple of online sites. Could this be what you need?
Les is more.
Luvmevolvo
- Year and Model: 2000 S40
I had a similar problem. It seemed to leak a bit from that plug after we replaced the radiator hours earlier so my husband checked and started tightening the draining plug (plastic and cheap) and it snapped, leaving half inside. The plug looked like it was toasted so that's why it snapped off. We managed to remove the very flushed, snapped off piece from the hole and we just used a galvanized screw that fit in the thread in its place. No more leak there.
- 16 Replies
- 4497 Views
Last post by granite
- 16 Replies
- 5407 Views
Last post by lcc014
- 1645 Views
Last post by DanSC
- 4136 Views
Last post by SuperHerman
- 2716 Views
Last post by oragex
