1995 850 what have i done?
- 57gretsch
- Year and Model: 2005 XC90 T6
- Been thanked: 2 times
While investigating the dtc for a3 142...I found a ground connection that was not attached. Two ground attachments near the brake light switch, to the left. I plugged it back on. There was clicking from under the hood and the courtesy light seemed to get brighter. After that... no start and dtc code for port a3 shows 444 no power to abs. Have I inadvertantly fried a relay somewhere?
No good deed ever goes unpunished.
1997 855 T5, 2000 V70XC, 1998 V70 AWD Manual, 2007 XC70
- 57gretsch
Well...the ground wire was for the chime. The no start was the PNP switch ( i must refurbish that.) But...it seems the the ABS control unit is beginning to fail. The first sign was the 142 code. I cannot find any reasonable cause. When the 444 code appeared I checked all fuses and come to the conclusion that it is on its way out.
- 551 Views
Last post by Cees Klumper
- 851 Views
Last post by Georgeandkira
- 929 Views
- 1351 Views
Last post by BlackBart
- 1887 Views
Last post by rspi
