I am trying to re-install my rear bumper, and typically my laptop with Vida on has decided to crash. Has anyone got access to the toque values for the 2 bumper bracket bolts and the through bolt for the bumper? It appears to be a weird size of bolt. Looks like M9?
Thanks,
P80 Rear bumper mount and bolt torque
- Has thanked: 2199 times
Well, I am assuming due to the lack of help, that you all came up against the no information position I came to after my laptop decided to work again.
Went with 8mm diameter bolt torque value of 25 Nm for both bolt types. Weird thing as I said was that both bolt shaft measured at 9mm. Thread may measure at 10mm. Bolt torque for these are clearly not critical. I used 25Nm as the bolts were greased.
Neil
Neil
