04 S60 Non Turbo. Transmission Questions.
joo070772
Year and Model: V70 XC 2001
Post by joo070772 »
Hello,
I'm having an issue as follows:
1. Massive vibration issue when it's in reverse only.
2. Some bang shift 1 -> 2 gear at low RPM (below 2000rpm)
-> Before overhaul the transmission, never happened.
1. Due to reverse was not engaged, overhualed transmission at 3rd party shop this Jan. 2015.
2. Only cleaned the the valvebody while overhaul the transmission.
3. Updated the transmission torque mount.
4. Updated the front & rear engine mount.
5. Installed the universal in-line ATF filter.
5. Did not update the front passenger side mount.
6. Did not update the upper engine torque mount.
The last month, checked the TCM/ECM at indi local Volvo shop.
Per VIDA Dice:
1. No TCM error code.
2. All comunication as Ready.
3. Found it only ETM software need to be updated.
Questions:
- Shoud I change the front passenger side & upper engine torque mount?
- Should I re-alingn the all engine & transmission mounts?
2. Some bang shift 1 -> 2 gear at low RPM.
- Should I repalce the new(remanufactured) valvebody?
- Has to be re-updated all TCM/ETM software?
Many thank you.
Joel J Beneduct Lee.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
joo070772 wrote:...
... overhualed transmission at 3rd party shop this Jan. 2015.
You have sufficient grounds to demand that the 3rd party shop address it
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
