2001 V70 Oil Leak Back of Engine
2001 - 2007 XC-70
Has thanked: 376 times
Been thanked: 1176 times
Re: 2001 V70 Oil Leak Back of Engine
It really doesn't make sense to fix this. With my target for the car life of 200k miles in reach, I think this will go to the next owner is year or two. If you aren't seeing any oil use on the dipstick, clean it once a year like me.
Link To Volvo Glossary
altalake
Year and Model: V70 T5 2001
Post by altalake »
Good advice. Next major routine maintenance is timing belt and even that's a year away at this rate. Not quite the longevity of my 544s but a lot less rust - and maybe a wee bit safer.
h20ham
Year and Model: 1998 xc
Post by h20ham »
Know its an old post. I am stumped as well. Same place. Was it ever fixed, or a cracked head?
Thanks
96 855t Automatic AC
It seems to under top portion of head.
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
95 965 T shift controller in progress
05 xc90 rough idle
Did you replace the turbo oil return line and gasket (o ring) ?
I had a heavily oiled engine which magically cleaned up when I replaced that
Oil from that o ring will hit the axle shaft and spray up oil and create seepage looking points I chased for two years
One $5 o ring, dry engine!
h20ham
Post by h20ham »
The oil is coming from the front of the engine, at firewall
Or passenger side (LHD) again, front
It leaks when hot, indicating seal.
It must be between cylinder heads. Or cam cover
Sorry, should have stated its a 96 850t
So no exhaust vvt
And outside of a crack, maybe the exhaust manifold studs protruding because maybe engine mounts are dyeing
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
abscate wrote: Wed Jun 01, 2016 4:16 am It really doesn't make sense to fix this. With my target for the car life of 200k miles in reach, I think this will go to the next owner is year or two. If you aren't seeing any oil use on the dipstick, clean it once a year like me.
What a wanker I am. Almost two years past “ target life”
Now it’s 300k, 2023.
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 75 times
Post by vtl »
abscate wrote: Sat Nov 30, 2019 3:34 pmNow it’s 300k, 2023.
Are you going to get rid of a perfectly fine car that just had the piston rings finally fully settled in? =)
05 XC70 265k, 16 XC60 45k, 19 Tundra 5k
