Did you know? 🤔
2000 V70 XC White
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
cvergi01
Year and Model: 2000 V70XC
Has thanked: 0
Been thanked: 0
United States of America
cvergi01
2000 V70 XC White
Post by cvergi01 » Tue Nov 10, 2015 11:45 pm
Maintenance
152000 - 155000
Coolant drain and fill
Rear hatch short to lock and brake light fixed
Detailed Interior
Replaced RF outer tie rod
Cleaned headliner
Fixed oil leak (turbo drain to oil pan)
Replaced both fog light bulbs
Replaced both headlights
Performance/Aftermarket
152000 - 155000 miles
"Brushed titanium" vinyl trim.
GlowShift boost gauge
TD04HL-16T turbo upgrade
ARD TCV
ARD ECU tune
IPD Poly subframe bushings
IPD Short ram intake
IPD Heavy duty endlinks
IPD LED Instrument cluster bulbs
LED Interior bulbs
Weather tech rain guards
MIL
155000 - cat efficiency below threshold - cleared and recheck
"I'm bored, I'm gonna go work on the car"
"Again?!?"
cvergi01
Has thanked: 0
Been thanked: 0
cvergi01
Re: 2000 V70 XC White
Post by cvergi01 » Tue Nov 10, 2015 11:49 pm
To do
Replace squeaky rear hatch struts
Sew rear passenger seat
Replace peeling door panel inserts
Oil change
Replace windshield
Check alignment
Replace diff fluid
Replace ATF
Replace Vacuum lines
Relocate TCV
Find passenger side squeak
Fix glovebox squeak
Rotate tires
"Again?!?"
cvergi01
Has thanked: 0
Been thanked: 0
cvergi01
Post by cvergi01 » Fri Nov 13, 2015 7:06 pm
155000
Lubed squeaky rear hatch struts
Adjusted hood latch (drivers side still doesn't work first time)
Resealed hatch weatherstripping
Replaced windshield
Replaced broken parking brake trim piece
Replaced RR inner door panel
Replaced glovebox trim piece
"Again?!?"
cvergi01
Has thanked: 0
Been thanked: 0
cvergi01
Post by cvergi01 » Mon Nov 16, 2015 9:24 pm
155000
IPD intermittent wiper relay
Replaced burnt switch bulbs
"Again?!?"
cvergi01
Has thanked: 0
Been thanked: 0
cvergi01
Post by cvergi01 » Sat Nov 28, 2015 11:30 pm
158000
Replaced windshield...again. Defective first windshield
Replaced passenger headlamp housing
Do88 intake pipe, custom fit into IPD short ram housing.
MIL - P1711 Long term fuel trim High limit.
"Again?!?"
