1998 S70 GLT Excessive Steam from Exhaust
ferocity02
Year and Model: 1998 S70 GLT
Been thanked: 14 times
Post by ferocity02 »
Ever since I've had this car I noticed that it seems to steam out of the exhaust when cold for an excessively long period of time while other cars on the road aren't steaming. Both coolant and oil levels are stable.
My wife drives the car and uses it for short trips mostly, averaging ~3 miles per trip I'd guess. My thought was that these short trips are leading to the collection of water condensation inside the exhaust or muffler. Due to the lack of long trips, it never gets a chance to burn off.
Is this an "issue" on these cars? On my 335i the mufflers collect an amazing amount of water. I drained out about a gallon once! The solution was to drill a small hole (~1/16) in the bottom of the muffler which lets the water drain out slowly.
Has thanked: 1611 times
Been thanked: 4072 times
Those short trips are killers. You do have massive amounts of water in your exhaust, in addition, your PCV will plug on an early P80 car (pre1999).
Do the glove test on your car immediately - you can save yourself 1000s of repair $$$$ if you catch this early
ferocity02
abscate wrote:Those short trips are killers. You do have massive amounts of water in your exhaust, in addition, your PCV will plug on an early P80 car (pre1999).
The entire PCV system was replaced 10k ago, as well as all vacuum lines replaced and the PTC valve cleaned. It passes the balloon test just fine.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I noticed the same thing with my T5, never had any issues with the engine or exhaust. I wouldn't worry about it
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
polskamafia mjl
Has thanked: 19 times
Post by polskamafia mjl »
ferocity02 wrote: Is this an "issue" on these cars?
Its an issue on every car. Short trips don't allow for enough heat to build up and boil off any water in the system.
Has thanked: 2209 times
Been thanked: 1852 times
Our old 98 V70XC in low temps, used to leave everything behind it in a cloud until it was fully warm. The issue lessened when the car was given an occasional long run to fully dry the muffler system out. Also worth checking your SAS pump is not full of moisture. The valve at the top of the turbo fails and allows moisture to drain down into the pump. I'm convinced this allows moisture to be drawn back up when cold.
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
scot850 wrote:... Also worth checking your SAS pump is no longer installed ...
Fixed that for you. :D
Ou2mame
Year and Model: 2004 xc90
Post by Ou2mame »
Try driving the car on line trips once in a while. My gf drives her car about 2 miles to the train station, so I make sure to take it on long trips on the weekends at least, if for nothing else but to charge the battery.
ferocity02
scot850 wrote:Our old 98 V70XC in low temps, used to leave everything behind it in a cloud until it was fully warm. The issue lessened when the car was given an occasional long run to fully dry the muffler system out. Also worth checking your SAS pump is not full of moisture. The valve at the top of the turbo fails and allows moisture to drain down into the pump. I'm convinced this allows moisture to be drawn back up when cold.
I can feel the SAS pump sucking in air from the hose that connects to the airbox, so it's working. I suppose I can check it for moisture and see if the check valve on top of the turbo is working. Unfortunately I can't delete the pump for emissions reasons.
Post by erikv11 »
Alas. FWIW, if Californians are looking for working, used SAS pumps and SAS valves, I have some I am happy to send out. Especially the 850 pumps. $5 per part plus shipping. Just taking up space in my garage.
