For fun, I hooked up a boost gauge to the vacuum tree on my 98 S70 GLT. At WOT below 4k RPM the most boost I see is 6-7psi. I would go over 4k RPM but it's the wife's ride and don't want the sh*tstorm that would come with breaking it.
Is this an acceptable amount of boost?
Is the boost adjustable? Can it be adjusted without tuning? Seems like the air-fuel ratio would be pretty far off if the boost was increased. I'm guessing these cars run in open-loop under WOT since the O2 sensors are narrowband?
1998 S70 GLT How much boost should I be seeing?
ferocity02
- Been thanked: 14 times
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
That is correct boost for that low pressure turbo car.
- Has thanked: 316 times
- Been thanked: 531 times
After reading around, I'd be VERY careful about adjusting boost. As in, I wouldn't do it. Get a tune before you do anything messing with the boost. You'll blow out the head gasket.
