I have a 1989 740, recently the oil warning light has been flickering after the engine is driven and warm
there is a noticeable ticking noise, The light disappears after the engine is switched off and rested for 5 minutes or so but comes back on after travelling a short distance. oil levels are good and new oil filter was fitted,any advise appreciated
1989 740 Oil warning light on dash
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
An oil pressure test would definitely help - but see if wiggling the sender wire (with the engine running) causes the light to flicker on the dash. The oil pressure sender wiring is prone to degradation - it squeezes between the accessory bracket on the block (lots of chafing), goes under the timing belt cover (where it is coated in oil from leaks) and then plugs into the sender on the exhaust side. I recently worked on a 740 with a flickering oil pressure light, and that wire was the issue - it was grounding out on the driver side accessory bracket. Ran a nice new wire with OE-ish wire sleeving (something like this) to protect it from oil/heat/abrasion for another 20 years/200,000 miles.
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
- 239 Views
Last post by 5rivers
- 1737 Views
Last post by E Showell
- 1390 Views
Last post by harojs
- 1408 Views
Last post by Salomons Driveway
- 2444 Views
