98 v70 which hose is this?
wuttheheeck
Year and Model: 98 v70 awd
Post by wuttheheeck »
Screen Shot 2015-11-14 at 1.15.44 PM.png (493.87 KiB) Viewed 771 times
Hey folks. Trying to replace fuel pump by cutting out access panel. I accidentally cut a hose and I don't know what it is. In this picture I clipped the black hose that runs parallel with the green hose?
What hose is it? Can I fix with a repair kit?
Thanks
wuttheheeck
its a softer/flexible hose
wuttheheeck
I'm think I found out where it goes, still curious on what it is and the function.
On this picture I believe it is connecting to the 'canister' where it says from fuel tank in the bottom right corner. I'm hoping I can repair it wit a barb.
More info is always appreciated
Has thanked: 2210 times
Been thanked: 1852 times
Sorry, but for the life of me I can't tell which hose you damaged. Can you clarify?
There are 2 hoses from the pump on the RHS of the tank as you show. The one to the left exiting the pump is the pipe that should go to the fuel filter, and then the filter to the engine.
The pipe to the right is the 'balancer' pipe that runs to the LHS of the tank and to the 'ejector' and fuel level for the LHS of the tank.
The 98 is a little different to the 00 that I have in terms of how it operates, and how the emissions work.
If I recall, the 98 has a feed from the fuel filter to the engine, and also a return pipe. The 00 I have has a single feed pipe and the return pipe is just for emissions and pressure balancing.
Here is a thread I wrote for the 00 fuel and emissions pipe layout. Mush of yours will be similar.
https://www.matthewsvolvosite.com/forums ... pe#p372714
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Sounds to me like you cut a line to the evap canister.
- S
[Sold] '97 S70 T5
Has thanked: 1611 times
Been thanked: 4075 times
EVAP canister line can be fixed with fuel line and clamps. The pressure line probably needs flare and unions as its under 50 psi
