2003 s80 nonturbo Removing water pump
Although a normally competent amateur mechanic for 50+ years, I am finally stumped while changing the timing belt & water pump. Water pump is unbolted & loose, but I can't get maneouver it out past the rear plastic timing belt cover, steel body pontoon, etc. Tensioners for serpentine & timing belts are out, along with the timing belt idler. Crank pulley for serpentine is off, leaving just the four-tab base that is splined onto the crankshaft The casting that has the timing mark on it. What else can be taken off to ease out the old water pump?.
Wichitas80
- Year and Model: S80 2002
Thermostat housing
oldironsights
- Year and Model: 2001 S80
I had to rotate the water pump to remove it from below. I did not touch the thermostat housing.
When removing the water pump from below, there is not enough room between unibody & engine to remove or install water pump (WP) in the correct orientation.
One must flip the water pump to where the drive pulley is facing the engine, not the shock tower in order to maneuver the WP down & out of the car. There is just enough room in my 2.9 to accomplish this task.
Install is just the reverse.
Gotta use your imagination! Remember that from your younger days?
I wish you success!
I wish you success!
oldironsights
It is quite tight in there.
If the job did not draw blood, you put in too little effort!
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
What I concluded from my tribulations with my T6 thermostat replacement is that the engineers somehow forget that all these components are a lot easier to install before the new engine is dropped into the engine bay. You can imagine how easy all this would be if the engine were sitting on a bench. I wonder what comments Volvo mechanics make every time training gets underway for these routine maintenance jobs on every new car generation.
Success in a matter of a minute via the 180 degree rotation. A no obscenity operation. Thanks again gents & to Old Ironsight for his iron insight. I should go into the shed and joyfully confirm the working space under the hood of my 1959 544.
oldironsights
Outstanding! Moose1.
Glad you got er done.
oldironsights
- 1283 Views
Last post by cypilot
- 1876 Views
Last post by 93Regina
- 4984 Views
Last post by kallekula
- 1368 Views
Last post by e777
- 231 Views
Last post by pinegrovedave
