2002 v40 Upper Engine Mount Passenger Side
robertg
Year and Model: v40 2001
Post by robertg »
Hello all,
I'm having an issue trying to remove the upper passenger side engine mount. I've removed the bolts but the thing won't move out. The mount is connected to the bracket from underneath so it seems that I have to take out both together. Does anybody have any ideas how to get this out? Am I missing a bolt I don't see?
pierremcalpine
Year and Model: V40 2003, V70 2010
Has thanked: 2 times
Been thanked: 5 times
Post by pierremcalpine »
The weight of the engine is probably putting just enough pressure on the bolt to prevent removal. Just put a jack under the oil pan supporting the oil pan with a piece of wood and lift ever so slightly and you will be fine. Keep the engine supported until you have got the new one back on.
alschnertz
Year and Model: 1995 854T
Been thanked: 12 times
Post by alschnertz »
I seem to remember having to lower the engine, as mentioned, to remove that mount.
And I would have done it just as pierremclpine suggested.
'84 Prelude
'06 MPV
'13 Ford Focus SE
