2010 S80 - Replacing part
Frank Drebin
- Year and Model: S80 T6 2000
Should be pretty straight forward. You'll need some type of counterhold to keep the bolt/ball steady while removing the nut - I'm guessing either torx on the inside end of the bolt, or "cutouts" for a wrench between the ball and the sway bar (there's probably a proper name for this, but I don't know what it's called).
You'll also need a crow bar to bend the sway bar down when you're installing a new end link.
- 9178 Views
Last post by IronMike
- 1503 Views
- 983 Views
Last post by pgill
- 361 Views
Last post by FastidiousSwede
- 769 Views
Last post by jimmy57
