2005 V70NAM56 Rear running lightsFuse 5, rear box Topic is solved
Has thanked: 1609 times
Been thanked: 4063 times
Just have the P2 to Mom to drive and noticed no taillights or front running lights.
DRLs are turned off on this car.
Headlights and high beams work fine
Brake lights, turn flashers, hazards all work
Checked fuse 18 per diagram and its ok.
Away for three days - not critical as Mom only drives daytime but will need to address for next week.
Any hints on troubleshooting modules?
Problem diagnosed in about 5 minutes
Rear driver electrical panel removed, checked fuse 5 for Rear Electronic Control Module. found dark oxidation on fuse pins, cleaned with Swiss Army knife, reinserted.
All lights functioning again.
Lights out again. Police acted as burnt bulb indicator. Will check fuse in morning.
Nailed it. Same problem
Opening the door to the REM
Location of Rear Light Fuse 10 Amp
Lights working!
Lights working!
Good cleaned up
Good cleaned up
Nasty fuse
Nasty fuse
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Great find. I often see that discoloration on Volvo fuses. It's odd that a low wattage circuit should have corroded contacts. Perhaps tin the fuses with solder?
I'm running non Canbus friendly LEDs on my rear brake lights to combat the inevitable melting of the housing around the globe holders due to the heat from 21W globes. Each time I press the brake pedal the DIM tells me the brake lights are out :?
No warning from the DIM on this one, but of course of it is a current comparator circuit, the two circuits were equally balanced at 0!
I’ll confess I am wondering how long these were out. I dont the drive much at night. Car last inspected in Sep 2017.
Technical correction
Fuse 5 is not for the tail lights, but listed as the "REM" fuse.
Failed MOT due to no reversing lights
This time it’s fuse #1. Cleaning and reinserting cleared fault. Done by my shop as they had my notes in the log
And rinse and repeat this problem in November 2022, at 142500 miles
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Could it be humidity-related?
