1998 S70 motor turns makes winding noise when starting
First of all I am a female Volvo owner, so excuse my car lingo. Going down the road hear clicking noise under hood, car starts to lose power and dies. When I raised the hood it was steaming, I'm assuming it ran hot, but temp. gauge was normal. After adding fluid when I tried to start it, it was making a winding noise, but the motor was turning. Someone told me to check timing belt, it was fine. Any suggestions?
jcdillin
- Year and Model: 06 V70R
- Been thanked: 3 times
Yeah, likely that you developed a bad oil leak from somewhere on the engine which in turn drained out all your oil. The steaming was from the large amount of heat generated by the lack of lubrication.
At least from this end it looks like your engine is close to or completely seized up which in most cases means your looking at a replacement.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
OK, tell us a little more about you and your car. Is it in otherwise good shape? have you owned it a while? Is it a base model, GLT, or T-5? Do you LIKE the car? Are you willing and able to do some of the work on it, or can you afford to pay someone else to? These will let us know which advice to give you.
PM sent
PM sent
Current Volvos:
- FLXC90
Check the upper left of the page where it says User Control Panel (X new messages) I sent you one
Current Volvos:
