97 855 t5 Seized bolt for transmission mount
GeekWarrior77
- Year and Model: 850t5 1997
Changing out my lower engine mount and transmission mount due to clunky shifting. All went well until I hit a seized bolt on the transmission mount. It's one of the two bolted into the transmission housing. I'm guessing its the steel-to-aluminum phenomenon I've read about. I've started to damage the bolt so I'm taking it to my mechanic right down the street. When I put the new bolts in I assume I should use a some sort of preventative. Anti seize? Locktite blue? What do you think? Thanks.
GeekWarrior77
Thanks. That's what I used. Mechanic got the bolt. New mount in place. The clunk persists, unfortunately.
- Has thanked: 2200 times
Have you changed the mount under the crankshaft pulley? It I have found is the worst offender for clunks from the mounts.
- 907 Views
Last post by GreenMagicMan
- 18 Replies
- 4242 Views
Last post by SuperHerman
- 1349 Views
Last post by vtl
- 16 Replies
- 4418 Views
Last post by 1337
- 1065 Views
Last post by zjevik
