2005 s60 No heat on drivers side
jaybee123
Year and Model: S60 2.5t 2005
Post by jaybee123 »
Hi, the drivers side ecc does not blow hot air. The passenger side works fine and the drivers side blows cold air fine. No error codes are displayed. Does anyone know what the possible cause could be? Thanks
Homebrand
Year and Model: 2002 s60 2.4T
Been thanked: 3 times
Post by Homebrand »
Likely to be the actuators that control the flaps. The flaps control how much hot/cold air is vented/fanned into the car. Either the actuator/motor is kaput or a linkage may be broken or simply stuck.
jaybee123
Post by jaybee123 »
Thanks for the response. Are these easy to access under the dash or does it require lots of disassembly?
Vovo_merz
Year and Model: 2007 s60R
Post by Vovo_merz »
before doing any work first try to get the system calibrated its the most common problem, can be done by some one who has vida dice or a dealer for around $120
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
