2004 C70 Misfire cylinder 2 - make sure you ID cylinder correctly! Topic is solved
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Happy Thanksgiving all. I have a 04 C70 with a new head and it was running great. Now runs rough. Recently got a flashing CEL and Misfire cyl 2 code. Just tried replacing plugs, ignition coil, and MAF. No luck. I have ordered a fuel injector to replace the original on #2. Any other suggestions to look at or other things I should consider while I await the injector part arrival from the MVS sponsor? THanks
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I had the flashing cell an rough running when an injector went bad. but then it went bad because I tried to check the flow with solvent (bad idea). anyone did play with the injectors recently ? maybe a leaking injector seal when they were removed.
cuhfs
Car was running great for about 2 months or so, since new head. No issues. Then this week just started running rough and flashing CEL with code. I figure I would just put a new injector in since it was original 120,000 miles. This way I only mess around with 1 injector and port instead of 2 injectors moving them around. Got one on sale closeout at IDP for $48 which was a pretty good price. Seems like from the responses so far that I am on the right track.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Yeah, aside from a valve or something mechanical (it doesn't sound like it) it should be either the injector, or the ECM. You could check for the voltage signal at the ECM for the injector. If it's not sending a signal, you have your answer.
"I'm bored, I'm gonna go work on the car"
"Again?!?"
"Again?!?"
cuhfs
Wanted to close this loop. Here's the rest of the story. I changed the "#2" fuel injector, "#2" coil pack, and MAF and did not fix it. Took it to the dealer and they replaced # 2 coil pack and it works fine now. I counted the cylinders from drivers side to passenger side. Come to learn the count starts from the passenger side. Schooled by the dealership for $300. Rookie mistake!
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
You should have emailed me.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
cuhfs
I hear your cars are in the shop???
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- E Showell
One is, another seems to have been fixed by an ECU contact clean and reseat. That just means I have time to help other Volvo enthusiasts fix their cars.
'95 855 auto (sold)
'95 855 auto (sold)
- Been thanked: 4063 times
1000 karmic points awarded for preventing the next gal/guy from making this mistake. Tough love fixing your own car sometimes.cuhfs wrote:Wanted to close this loop. Here's the rest of the story. I changed the "#2" fuel injector, "#2" coil pack, and MAF and did not fix it. Took it to the dealer and they replaced # 2 coil pack and it works fine now. I counted the cylinders from drivers side to passenger side. Come to learn the count starts from the passenger side. Schooled by the dealership for $300. Rookie mistake!
I chased all over electrical and fuel systems for three weeks on my 1999, took it to a Volvo indie who fixed it in 30 seconds with a loose induction hose clamp.
- 1932 Views
Last post by WhatAmIDoing
- 3559 Views
Last post by befarrer
- 871 Views
- 569 Views
Last post by rspi
- 9462 Views
Last post by John65
