Will S60 wheel fit S70?
bw77
Year and Model: 99 S70GLT
Post by bw77 »
S60 alloy wheel is the same size, 15x6.5, same BCD 5x108, same offset 43, and same center bore 65.1.
Difference is that the S60 uses 14mm wheels bolts, and the S70 uses 12mm.
Will the 12mm wheel bolts tighten properly in the 2mm larger holes?
Thanks.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Should not be a problem.Head of the bolt is the one which counts in this case(larger part of the bolt keeps the wheel tight against hub).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
