'98 V70 Outer Tie Rod Won't Come Off
echase76
Year and Model: 1998 v70 T5m
Post by echase76 »
Hi Folks,
In the middle of doing a front end refresh (Bilstein TC kit plus endlinks) and found my outter tie rods are shot while working in there. Ordered a couple up from FCP and expected an hour to do both. Well, Passenger side was all of 10 minutes, but 3 hours later and I can't get the divers side off :evil: . The jamb nut is lose, but no matter what I do I can't get the end off.
Options:
1) torch...I don't have a torch but am willing to get one if that is what it takes.
2) Order up the inner and turn it into a slightly bigger job. Downside is wife will be without her car for a few more days.
Open to any other tips and tricks. What I'm finding is that is it hard to get a good grip and brace on that inner tie rod to really get enough torque.
1998 V70 T5m Silver/Charcoal - 150K
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
If you have a pickle fork use it, if not several whacks on the spindle with a 5lb hammer will work.
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
soak it with penatrene or other penetrating oil, and leave overnight.
echase76
Post by echase76 »
Thanks guys. After reevaluating the situation it appears that my inner is shot too Found a rip in the boot and I see rust in there.
Guess I'll go for it all and not worry that the outter won't unscrew off the inner.
Cheers!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Torch will make it a lot easier and faster.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
I got the jam nut loose by banging as hard as I could on a wrench with a sledgehammer. It was a combination of PB Blaster and rage-whacking.
The nut was so stuck in place that the wrench flats on the tie rod were being rounded off by the wrench I was using on them. I ended up using a vice grip supported by a jack stand to prevent torquing the thing at its end connections and breaking anything besides the jam nut.
I was so happy when I got that thing loose. I thought it would never happen.
j-dawg
Post by j-dawg »
Also, I bought that wrench. I learned the hard way - you absolutely need the correct wrench. If you try to use a crescent wrench, pipe wrench, Ford wrench, anything short of an open-end wrench of the correct size (21mm?), it will not work. A flare-nut wrench might be even better if you can find one that big. It'll add a little more resistance to rounding off the nut.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
j-dawg wrote:... I was so happy when I got that thing loose. I thought it would never happen.
Success, nicely done!
benpineapple
Year and Model: '06 V50 T5, '13 XC90
Has thanked: 5 times
Been thanked: 4 times
Post by benpineapple »
Oh wow I'm getting stressed just hearing about it. Nice work on the removal. Was the inner tie-rod as much of a pain?
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
That just happened to me on my 2000 S70. One outer was rot-welded to the inner tie rod, and impossible to remove with Kroil, large pipe wrenches & then with fire. I replaced both inner and outer. It took a hacksaw to cut the nut, then a chisel to spread the nut in order to take them apart!
This is why I'm a firm believer in using anti-seize. I put the $hit on everything!
'00 S70, '04 S60 and the never ending quest for Stage Zero
