On this cold night, I was going to replace the pintle caps, spacers, and O-rings on all four injectors. I ordered the bosch part set: 1 287 010 704 which says it fits 1990 Volvo 240. Although from the pictures I have taken, it appears the new grey spacers inside diameter are too large. Also there is a height difference between the new grey spacer and the yellow spacer.
I am worried about the spray pattern being off if I use the new spacer with the new pintle caps.
The vague directions say:
Please note: 1. The old protective sleeve must not be removed from the injector valves with yellow supporting plates. 2. Only use flat seal ring and O-ring (1 item) when a pressure regulator intended for use with O-rings is replaced.
Do I just reuse the old yellow spacers with the new pintle caps and call it good, or did I order the wrong parts?
Thank you again in advance for any help or advice!
Andy
http://imgur.com/A6YIFIR
http://imgur.com/e5DyRk5
http://imgur.com/1REPkbs
http://imgur.com/6R4nni1
Fuel Injector o-ring kit spacer is larger than original. Is that normal?
durk80
- Year and Model: 240 DL 1990
Isn't there also be a lower sealing grommet that helps to keep the injector in place, or I am I just crazy for thinking that. My 850 has them on the intake manifold. My abused 240 did not come with any and I could smell a strong fuel smell. These are the seals that I believe should be on the intake manifold for the injectors to sit on https://www.fcpeuro.com/products/volvo- ... er-3528217 The car does have EGR too if that matters.
Can anyone verify this or point me in the right direction?
Thanks for all of the expert advice in advance!
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
These fuel injector seal kits are available at NAPA :
Mileage Plus Fuel: MPF 312085 $4.29 ea.
Reinz: ATM 153664101 $10.19 ea.
Bosch: ATM 1287010704 $13.76 ea.
Echlin: CRB 212085 $6.99 each
1988 Volvo 760 Turbo Wagon
[QUOTE=T501;3519913]+1 on OEM injectors. Not cheap but it'll be "one and done."[/QUOTE]
Hello all,
Am new to this community, am working on a 960 Volvo to put an M90 into it and am buying two 850 MT that have sat in a garage for a year. I have done extensive work on diesels, like engine rebuilds and have done diesel injectors of the older type.
MY QUESTION: Has anyone built or rebuilt Bosch injectors for the 1990-1997 cars like the 850-940-960?
I saw the info on O-RINGS but wonder if full-blown kits for injectors exist and who makes them, where they can be gotten,etc. Also: procedures. Have not seen anything in my 6 Internet searches.
Certainly it would be easier than rebuilding the diesel injectors because the pressures are so much lower and thus less dangerous. What about parts suppliers? Procedures? Things to watch out for? Are there alternative all metal injectors for the Volvos?
Just asking, would really like info if available.
Thanks!
Hello all,
Thanks!
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
BOSCH TYPE 3 injectors seldom clog, but to "rebuild" can only mean someone had an injector stand, and watched spray patterns, and then slapped on a kit like this.960orbust wrote:Has anyone built or rebuilt Bosch injectors
There are ebay resellers who have the injector equipment, and do this, but always confirm if the dude has an injector shop. Too many Pick-n-Pull hustlers on ebay, with their motor-mouths running for your dollars.
Thanks for the info and the warnings.
I'm looking for spare parts I'll need sooner or later for the volvo 960.
Do these fit a volvo 960? A look at the kits discusses EV3 and EV6 injectors which ar5e GM and Chrysler. Could they also be Volvo?
- 93Regina
Based upon Bosch's literature, EV3/EV6' have differences in spray patterns available, and both are Gen III, but for EV3s, all are the same internally, with respect to filter used.960orbust wrote:...kits discusses EV3 and EV6 injectors...
I believe that kit will work on all of these vehicles with 0280155746 injectors:
VOLVO 850 (1995 - 1997)
VOLVO 960 (1996 - 1997)
VOLVO S70 1998
VOLVO S90 (1997 - 1998)
VOLVO V70 1998
VOLVO V90 (1997 - 1998)
Electrically, there may be differences in Lag Time, etc. from one injector to another.
- 1029 Views
Last post by northernlights
- 1329 Views
- 2987 Views
- 13 Replies
- 4217 Views
Last post by Nixwe
- 12 Replies
- 5353 Views
Last post by pgill
