2006 V70 FWD nonturbo
The passenger side headlight is very dim, and it's aimed very low. So is the high beam.
I want to aim them higher to see if that solves the dim problem. I might just put in a brighter bulb.
I do not see anything in the car or on the internet on how to aim the beams....
Any help?
How to aim passenger side low and high beams upward?
jh_on_the_cape
- Year and Model: 2006 V70 n/a FWD
- Has thanked: 1 time
Bright Red 1994 850 Wagon, nonturbo, FWD, stickshift 150k-ish miles SOLD
2006 v70 FWD nonturbo, boring silver A/T, 200k miles
There should have two bolt/ screw on top. You may adjust it.
1996 850 T5
2005 V70R
2005 V70R
- Been thanked: 4069 times
It may be aimed right but the reflector has tarnished. Pull up near a white wall or garage door to check
jh_on_the_cape
Thanks. I shined the lights on our garage door at night and both low and high beams are definitely too low.
I cannot find the adjustment screw? Is it hidden or obvious?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
These are hard to reach and hard to turn if they got stuck. You have to turn both at same time, I believe they turn in opposite direction.
http://www.volvoxc.com/resources/how-to ... djustment/
Or you may have the automatic level adjustment and in that case is quite normal for the little electric motor to fail.
For the bulb itself, old bulbs dim, perhaps it's time for a new H7 if it has regular bulbs.
jh_on_the_cape
How can I tell if I have the auto level adjust?
I looked at that link and the picture. Is that the passenger or driver side?
I was going to put in a new bulb, but that side is dim on both hi and low beam.
jh_on_the_cape
OK I found the adjustment knobs. On the drivers side I turn it and the light goes up and down.
Passenger side I turn it and no change which makes me thing the little gear in there is bad and the light is just shining down.
How do I replace that little piece? Or even superglue it into the right position? Car has 170k and we go skiing now and it's pretty dark on the way home.
Thanks.
Thanks.
- oragex
Are there two adjustment knobs at each headlight? I remember on my model I had to turn both knobs at same time (much easier to say than to do) or the light would not move. Don't quite understand the mechanics behind it, though. Also is good to verify the bulb is properly seated (the two knobs appear at the left of the picture at 0:53)
jh_on_the_cape
Yes when you spin the top one, the side knob also spins by itself.
I messed around with it and I am sure that those adjustment knobs do not work. The housing they move is facing all the way down, and when I turn the knob it spins in and out but does the housing does not move. I compared it with the other side.
I think however that adjuster connects to the housing is broken. I really hope that does not mean I have to replace the entire assembly.
This video shows it well
oragex wrote:Are there two adjustment knobs at each headlight? I remember on my model I had to turn both knobs at same time (much easier to say than to do) or the light would not move. Don't quite understand the mechanics behind it, though. Also is good to verify the bulb is properly seated (the two knobs appear at the left of the picture at 0:53)
jh_on_the_cape
Took it to the local volvo guy and he says I have to change the entire headlight assembly. Which takes like 2 hours. I found a YouTube video of the process and it's beyond my comfort zone.
Mechanic said to look on ebay for the light.
- 2003 Views
Last post by misha
- 1780 Views
Last post by BEJinFbk
- 1816 Views
Last post by Rattnalle
- 645 Views
Last post by Yaworski
- 15 Replies
- 4508 Views
Last post by shiloh51933
