I have a VERY intermittent "Low Coolant Warning" light coming on in my '04 V70 T5. My coolant level seems to be fine.
This is probably a stupid question, but is this just the coolant level sensor going bad?
I've not had this happen on any of my other Volvos, so I don't know if it's typical, or if it is indicative of a deeper problem.
'04 V70 Low Coolant Warning
Checking, if its any DTC there.
Add a bit coolant to a bit "over" max level.
Checking connection with sensor.Its may not well connected. ?
1996 850 T5
2005 V70R
2005 V70R
JeffHicks
- Year and Model: 1989 240 Wagon,
Thank you. I've been watching the coolant level. It seems stable.z2003 wrote:Checking, if its any DTC there.
I'll jiggle the connection again.
Oddly enough, the light didn't come at all today. Odd...
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Lucky choice is the float inside the reservoir gets stuck.
Unlucky one is the sensor at the bottom of the reservoir is kaput. It's fragile and will break when one lifts the reservoir without disconnecting the electrical plug.
- 48769 Views
Last post by ggleavitt
- 4082 Views
Last post by MathalomuleM31
- 5557 Views
Last post by Cees Klumper
- 11901 Views
Last post by fontoledo
- 2575 Views
Last post by prwood
