Can someone please help me id this?
I have a great mechanic, who upon noting a hole in one of the turbo hoses, proceeded to tape it, even though
it is under pressure and gushing oil everywhere. Give me a break, I am not a mechanic and don't have a dad.
This is probably supposed to be a hard hose all the way through, but mine has a soft hose connecting two hard hoses with
some clamps. The soft hose is taped at the clamp, as you can see. I had to retape it, as it isn't quite doing the job.
I have two pics: one of the top hose and another with the soft hose as seen from above. So there is the top hose, clamp, soft hose with hole and tape with a snake like texture, and then a hard hose that it connects to again below.
My question is, before I get reamed again, should I replace the soft hose with a hard hose or a soft hose? Can I get away with
something from the hardware store? I am on a tight budget. The two hard hoses above and below look intact but I am assuredly ruining my turbo with this mess. I don't have James Bond smoke coming out of the tailpipe yet.......
What part number/id is this please?
Thanks
Soft Hose indentification 1995 850 T WGN
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
If you're ok with spending a little more, this set will replace all the worn out soft hoses.
http://www.ebay.com/itm/Silicone-Boost- ... ma&vxp=mtr
If you just want a stock hose replacement, I think I have one $5 + shipping.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- Been thanked: 504 times
You can use the diagram from vivaperformance to have an idea of which hose is which:
http://www.vivaperformance.com/silicone ... c70-turbo/
- Year and Model: Many Volvos
- Been thanked: 76 times
I come up with an OEM part number of 9161091 for the hose. It won't hurt the turbo but it does kill the cars power if it is leaking.
I am just curious, has anyone tried the Mishimoto kit, about $182?
http://www.mishimoto.com/volvo-850-s70- ... 97-04.html
Thanks so much for all replies. I got the hose online for 11.00 with the OEM part number. I was quoted at least 60.00 just for the hose from every mechanic I asked. I realize now that the oil is a result of a clogged PCV system. This hose problem was causing sporadic power loss.
The damn thing had a hole in it!
- 876 Views
Last post by jimmy57
- 1336 Views
Last post by norbert
- 1304 Views
- 884 Views
Last post by shaker_chi
- 16 Replies
- 3704 Views
Last post by xHeart
