When applying brakes RPM's will drop dramatically
kitt57
Year and Model: S - 70 2000
Post by kitt57 »
I live in Dubai and own a 2000 Volvo S-70 which the engines was replaced in June/2013; since that time I have had repeated problems with ETM. I have replaced the Throttle Body with a new Volvo dealership ETM and software updated. But I am still experiencing the same problem that when applying the brakes the RPM's will drop well below the idle speed to the point the car shudders. Could this be the MAF (which I disconnected - no change), or maybe vacuum hoses? I appreciate any help or suggestions.
Has thanked: 1609 times
Been thanked: 4064 times
Welcome kitt! It's probably the brake booster check valve ( cheap) or the booster itself ( not cheap). You should also inspect all the vacuum hoses for leaks and tears too.
