Today was our coldest morning yet, around 35F (California). Went to start the S70 this morning and I got an AT-124 code (transmission mode selector low signal), flashing up arrow, and check engine light. The car drives fine. I cleared the codes and it didn't come back in a few miles.
About 2 months ago I cleaned out the range switch because reverse lights weren't working. I put a lot of dielectric grease in it, which I found out afterwards that I only should have used a little bit. Regardless, it has worked fine until now.
I'm curious if the cold weather combined with too much grease resulted in a bad connection inside the range switch.
Anyone else had a similar issue?
The car is a 1998 S70 GLT with 187K miles.
1998 S70 Cold Weather -> AT-124 Code and CE Light
ferocity02
- Been thanked: 14 times
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I doubt that grease is the culprit.Grease will not apsorb water or condensation and it's not conductive.It's there to prevent corrosion and to provide a good contact.
I don't see how too much of grease can make a problem.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
ferocity02
It was equally as cold this morning and it did not happen.
I'm going to consider it a fluke until it happens again. If it does, I'll report back.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Don't read too much into the weather being cold either - these cars are made for cold weather. My 850s have usually been living in around 5F temps during the winter, and never had an issue arise from that.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 325 Views
- 705 Views
Last post by MoVolvos
- 373 Views
Last post by crismit125
- 580 Views
- 676 Views
Last post by sane
