V70 back washer fluid stopped working
qwertyjjj
Year and Model: V70 2004
Has thanked: 1 time
Post by qwertyjjj »
It froze the other day before I had a chance to put in anti freeze. Since then the back washer fluid doesn't work. Front is fine.
The hole is not blocked, where can I check for the pipes?
This is a v70 2004
Has thanked: 1610 times
Been thanked: 4065 times
Are you getting pump action when you push switch? Listen for the pump with the engine off, ignition on.
qwertyjjj
Has thanked: 1 time
Post by qwertyjjj »
Can't hear the pump as the wipers are too loud.
Can't even hear the pump at front where the fluid works.
qwertyjjj
Has thanked: 1 time
Post by qwertyjjj »
Any ideas where the pipes from the front pump lead to the back?
Is there a storage back pump or just one?
qwertyjjj
Has thanked: 1 time
Post by qwertyjjj »
Bump
