Would 1998 toyota camry rims/tires fit on a 1999 volvo s80?
caj767314922
Year and Model: 2011Volvo
Post by caj767314922 »
They are aftermarket rims and nokian tires. Just curious.
Volvo S80
Year and Model: 1999
Has thanked: 7 times
Been thanked: 2 times
Post by Volvo S80 »
No they don't fit the differences are, centre bore 65.1 for Volvo and 60.1 for Toyota and the bolt pattern 5*108 for Volvo and 5*114,2 for Toyota.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Jaguar has the same pattern as Volvo though offset and bore size (centre hole) probably won't match being a RWD vehicle.
Volvo S80
Post by Volvo S80 »
The Jaguar wheels don`t fit Volvo S80 because the offset is 60, while in the Volvo maximum is 49. So if you install Jaguar wheels you will have rubber contact on the fender and on suspension parts.
So for Volvo S80 (1999-2006) wheel and tire options:
Tire;
Diameters:15.00''-19.00''
Width(mm): 205-245
Tire aspect:35-65
Smallest tire: 205/65/R15
Biggest tire: 245/35/R19
Wheels;
Bolt pattern:5*108
Width(inches):6.5-9
Offset:35-49
Center bore:65.1 ( If center bore is bigger than 65.1 but other dimensions are as mentioned than those wheels can be fitted to your Volvo by using hub rings)
